I have an interesting cut that I want to make. It is on a curbed surface that is curbed in box the X and Y axes. I'm cutting on the Z axis.
Also to this trimmed surface, I want to add an edge trim part... sort of like the stuff used for car doors, sometimes called rubber trim. How can I control how the sweep rotates around the sweep trajectory? It seems that if I had two trajectories, the sweep could follow the main one and then rotate along the other.
Alfonso
Alfonso Medina O. Mechanical Engineer
