display search path in wildfire 3.0
  • April 15, 2014
  • 2 replies
  • 4333 views
Is there a parameter to display search path on bottom of drawing in wildfire 3.0?
Best answer by MartinHanak
Jason,
you can download and use my script.
Good luck
Martin Hanak
Jason,
if you want to show path to directory where the drawing is located, then I think it is not possible.
Martin Hanak
diggs1-VisitorAuthor
i figured as much martin. so i just wrote a parameter and going to make the user write in the path each time
Jason,
if you add the following option into your config.pro file, then you will see the path in the window title.
display_full_object_path YES
If you have some programming knowledge, then (I hope) you can use AutoIt software and create a script which takes the path from window title and put it into specific parameter. Such script can be launched using ProE/Creo mapkey.
Martin Hanak
