When I drag an extrusion the dimension will only change by 0.100 inches. Therefore, if I have an extrusion of 0.500 inches and I want to drag the size of the extrusion with the mouse the extrusion will only change to 0.600 to 0.700 to 0.800 etc. I want to be able to drag the extrusion and have the dimension change by .005. Is there a configuration that I need to change? I tried setting the comp_snap_dist_tolerance to .005. This did not work.
I think you can do this by changing the config.pro options about handle movement intervals:
angle_grid_interval,
centimeter_grid_interval,
inch_grid_interval
etc...
The dimensional extrusion is based on the number of decimal places that you use in the part modeling.
It can be controlled using the config " default_dec_places".
I am not sure if it can be controlled as an incremental value for each drag.
inch_grid_interval
etc...
Thank you!
