hardware library question
I'm about to start creating a hardware library and any input is appreciated. Just so you know we have a numbering/ordering system that is customer/project based in which all parts are assigned a project specific number including hardware. With this system the hardware will be duplicated for each project.
Assuming we all agree that a highly detailed (threads) screw is not desirable, how much detail is enough. Are you using tables? pro-program? Is there any benefit or pitfall to creating a detailed screw, exporting as a parasolid and importing? Is anyone using vendor models (mcmaster)?
Pending feedback, my initial approach is to not use family tables, create a base model that others are duplicated from.
-hs
-hs
