Hi Gurus,
I am trying to find out a way to import zemax data into ProE to create the curve or to map the parameters used in ProE Curve equation.
Currently using the zemax txt data to manually map into the parameter created in ProE by typing or cut &paste.
Which makes it very time consuming not to mention havinga high error risk in the process.
My first thought was to import excel file to map the parameter, but no import option in parameter tool in ProE, I was confused with Intralink.
And my other thinking isto writesomerelation to map but only the txt file can be imported into relation.
This much is my limit of thinking and not going anywhere so far..
Can someone pleasehelp me make this possible or any insight or advice for that matter would be great.
We are using WF4.0 and no Intralink of course, that would solve the problem I am sure.
Best,
J.
