instance index file
llam
2-Explorer
instance index file
If you open an instance index file you can read which instance comes from what generic
Each line begins with either a 1 or a 2
Is is true that :
1 means instance is an assembly
2 means instance is a part
3 The number at the end of the first and last line is the total number of instances in the directory
INST_IDX 8
1 1004-411-02 1004-411-01
1 1004-414-02 1004-414-01
1 1004-780-0X 1004-780-01
1 1004-950-02 1004-950-01
1 1004-953-02 1004-953-01
1 1004-954-02 1004-954-01
1 INSTL-TC-CLAMP_INST-00 1004-910-01
2 1004-729-00 1004-729-01
INST_IDX 8
0 REPLIES 0
