menu_def.pro in Creo 2.0
BrianMorales
Does anyone out there utilize the menu_def.pro file in Creo 2.0, (with the exception of drawing mode)? In the past, we utilized the menu_def.pro to add additional menu picks to the Cosmetic Thread FEAT PARAM menu in order to quickly assign thread parameter to the feature. I can't figure out how to go about doing this in Creo 2.0 however.
This is the syntax we use in our Wildfire 4.0 menu_def.pro file.
@setbutton FEAT#PARAM **UNC-2A** "%unca;" "Modifies all thread parameters to \
selected thread size (.073 thru 1.750)"
@setbutton FEAT#PARAM **UNF-2A** "%unfa;" "Modifies all thread parameters to \
selected thread size (.060 thru 1.500)"
@setbutton FEAT#PARAM **UNC-2B** "%uncb;" "Modifies all thread parameters to \
I have attempted to modify the menu_def to reflect the menu changes in Creo 2.0 without success. I thought I would be able to get around this by adding a new "thread params" tab to the GUI, however once in the Thread menu, functionality in other tabs become unresponsive.
Brian Morales
Sandia National Laboratories
Albuquerque, NM
Organization 2997 Mail Stop 0648
Phone 505-844-5762
we only use menu_def.pro in Creo 2.0 in drawing mode - it works fine. I think it will not work without menu manager.
Andreas
