Hi
Is it possible to overide dimensions and show tolerance with it?
It's possible, use "Override Value" instead of use "@O", the tolerance is ok to with the dimension.
I want to show tolerance to overide dimension value CD
Regards
Samuel
It seem the tolerance also be overrided, but you can type the tolerance value follow the override dimension value CD.
no it not working
