pattern becoms inverted :-(
- January 15, 2020
- 2 replies
- 3170 views
Hi All,
I need to create a pattern like this...
I've built it about 10 differnt ways, but it seems to always fail on the inflection point here
I'm sure it something to do with normals being flipped for the curve as it goes over the apex. (start points on curve flipping from botttom to top - if you copy and paste the middle curve from the first group in the patter and conpare the direction start point to one from a failed group you can see what I'm talking about )
basically what I've done is create a spline, place a point at a real distance of say 5mm from start, another at 10mm and another at 15mm. (I tried patterning this 3 times to get 3 points at 5, 10 and 15 for construction but then Creo was complaining about patterning that)
I then constcted 3 curves that were normal to the spline and through each point
then a new sketch over that to add rounds
then I pattern that construction and final sketch to give me the geom I need.
I did maybe 10 variations of this, diferent ways of constructing the same geom but they al fail on inflection where the arcs on the last sketch jump to the opposite end
I've tried also constructing offsets and using edge and trimming to get the underlying geom to add full rounds afterwards but it just fails at inflection again.
If I unpattern it, and go to where it fails, a simple sketch update references solves it..
it's very annoying.. 😖
Creo 5 part file attached for anyone willing to take a look.
any help appreciated
James
