pin connection
chris5
pin connection
This is my first time on this forum. Why does a hinge (2 elements) loose his pin connection (more specific his rotation axes and limits and so on)in an other asm. In my case they are 3 of them in a pattern. Can anyone help me solve this? I am a beginner (4 months on Pro-E WF5 an all alone on the job)
If the hinge works by itself, and it works when it's the latest component added to the assembly, it's probably getting messed up by a component that was added later on. Roll back the assembly to find the offending component and redefine its constraints correctly. There might be a problem with the hinge assembly itself, but I can't tell without seeing it. Can you upload an assembly that would illustrate your problem?
This is the asm, sorry now I see I can not upload an ASM. How can I fix that?
Looks like you can zip it and upload as long as it's smaller than 2MB. http://www.ptc.com/forums/attach_rules.php?f=17 Or host the files on a site like dropbox and provide a link. https://www.dropbox.com/referrals/NTY4MDYwNzk
