prehighlighting of imported geometry
ArnoldCollett
Here is my mapkey that toggles it on and off.
!THIS MAPKEY TOGGLES PRE-HIGHLIGHTING!
mapkey vph @MAPKEY_LABELPrehighlighting;~ Command `ProCmdOaSelFilter` ;\
mapkey(continued) ~ Activate `selprefs` `PrehButton` ;~ Activate `selprefs` `Ok`;
Thank you,
Arnold Collett
Mechanical Designer
Design Integration
Intergraph building 23B (48-238)
Bay 102, Cube 1069
(phone) 256-542-6848
Boeing HDC
Greetings all - thanks for the many responses, however, what I did not
clarify is: regardless the use a mapkey to turn off/on preselect
highlighting is irrelevant to this issue. The issue being: at some point in
time the preselect has to be turned on in order to activate any of the
geometry. When you have a large imported model in an asm, the model will
always highlight when the cursor cruises over it... If preselect is turned
off, then it is a hit or miss deal selecting/activating geometry, which is
very cumbersome/frustrating. My question earlier was meant to ask if
anybody has created a way to single out certain geometry so that it does not
highlight, yet be able to use its geometry.
Best regards
Kelly Gensley
Genz Design & Machine L.L.C
Box 232
Victor, Iowa 52347
Ph: 319-444-0261
Email: -
"Nothing of Value comes without being earned"-Anonymous-
CONFIDENTIALITY NOTICE. The information contained in this e-mail, and any
attachment therein, is CONFIDENTIAL and for use only by the addressee and
solely for authorized purposes. If you are not the intended recipient,
please return the e-mail to the sender and irreversibly delete it from your
computer. Unauthorized copying, distribution or dissemination of this email
or any attachments is prohibited and is the confidential property of the
sender. Sender does not guarantee that the email and attachments are
virus-free, and accepts no liability for any damage sustained as a result of
viruses.
Query select.
We turned off preselect highlighting on Day 2 with Wildfire (mostly due
to slow redraw when working with large, complex Merge features), and
still find that QS works just fine for us.
Jonathan
