how to show all the components in the BOM of an assembly which is assembled from several subassemblies?
for instance, assembly A is assembled from part B, C and subassembly D, and D consists of X,Y,Z. in the BOM, only B, C and ASM D are shown, but i want to show B, C, X, Y, Z in the same BOM, how to do that?
really urgent, thanks a lot!!!!!!
You use the recursive command. Here's the click order,
table tab, [repeat region]
[flat/rec item]
choose the table by single clicking it
the recursive item will pop up, choose all items in the table by box selecting
click done and your table should be expanded
[flat/rec item]
thanks a lot!! sorry for late reply, there were sth wrong with my internet, but you did help me solved this problem, thanks again!
