Has anyone seen an issue with the display of the appearance gallery before? Please view the attached image. If so, please advise what the issue and solution was.
Thanks in advance!
We had this problem and it seemed to be related to the homepage we had set for start-up. You might try a homepage with no images or graphicsand see if that takes care of the problem. I'm not sure what the root cause is, however.
