"snap" lockout on component placement???
pdkoren
7-Bedrock
I can't seem to locate the option/control for setting the "snap" for manually moving a component with an offset constraint. Help? I'm not sure that's what it's called, "snap", but basically when I assemble a new component with an offset constraint, orwhen redefining it, I can click on the white control dot and drag the component with my mouse, changing the offset dimension. My system currently "snaps" to even number offsets, since it's a metric assembly, it snaps to whole numbers of mm...1, 2, 3... ect... This was fine at my last work assignment, but now I'm working on much, muchsmaller parts and I would like to reduce this.
thanks in advance...
Paul.
config option millimeter_grid_interval should do it.
/Bjarne
Paul Korenkiewicz <->
21-12-2011 20:56
Please respond to
To
cc
Subject
[proecad] - "snap" lockout on component placement???
component with an offset constraint, or when redefining it, I can click
much, much smaller parts and I would like to reduce this.
Paul.
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
