Eric,
That's not how the reference pattern a patterned pattern works.
First, you create a pattern. Then you pattern that pattern. When you assemble a component to the lead feature of the lead pattern, then the reference pattern gives you the Group and Both options. It doesn't work if you pattern a component that contains a pattern itself.
David R. Martin II
Senior CAD Application Specialist
Amazon
