I have a repeat region relation assigning a value to a string parameter.
req = "8"
Anything that we enter into the quotes goes in the parameter and show up
in the BOM. my problem is that the item in question is a bulk item with a
quantity in inches. I want this:
req = "8"
this entry throw an error. is there a syntax that will allow this in the
relation assignment? Or will I have to make a part parameter to hold the
value then set req equal to the part parameter?
req = asm_mbr_bulk
Eric Henriksen
Entegee Engineering
Davenport,IA
