return to active window?
lylebeidler
WF3 question. Occasionally, when I print a drawing, after the print dialog
box & MS Printer Manager dialog box go away (this only happens when printing
through MS Printer Manager), the first pro/E window in the window list will
pop to the front. The window I printed from will still be active, but will
be "behind" the first window, for want of a better term. It's the same
effect you get if you Alt-Tab from one drawing window to another.
I have two questions about this:
1) is there a way to get this to stop happening?
2) if not, is there a shortcut way to bring the active window to the
foreground? I know I can alt-tab it, or go to the Window menu, but what I
really want is a keyboard or menu pick that is the equivalent of "bring the
active window to the foreground" Is this possible?
Thanks in advance.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
0 REPLIES 0
