Hello everyone,
I met a problem when doing simulation on the connection part. I tried to provied some force on the connection interface(see the attachment), but the analysis failed and the diagnostics says : Run completed with fatal error. Do you have any suggestions on that?
Thanks a lot:)
Your constraint is fully fixing the surface.
Your load is acting on the same face.
The constraint will win and nothing will happen.
The software will warn of this load/constraint conflict in the diagnostics.
This load/constraint conflict is not the reason the model fails.
There is another problem somewhere.
Regards
Hi ,
Thanks for your reply, I fixed that and it works now ![]()
