tell pro/e to ignore a certain component when running mass props analysis?
lylebeidler
Is it possible to tell pro/e to ignore a certain component when running a
mass props analysis on an assembly?
Note that I don't want to set the density of the component to zero or
anything like that.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Can you make a simplified rep to exclude that component and the run the mass properties on the simplified rep assembly? Not sure if that will work or not...?
Ted
