tiny pattern 0.004mm
amedina
The smallest I can go on my part is .01mm. Is there some way that I can
make the pattern even smaller to 0.004mm?
I played around with the accuracy and that didn't really help. Any ideas as
to what I'm doing wrong here?
The part is a large disk with diameter 14mm and thickness .015mm
At the center I am making some .002mm diameter holes spaced by .004mm in a
sketched circle with triangular arrangement
regards,
Alfonso
amedina
(To:amedina)
Doug, Ben and Brent. Thanks for the help. I guess there is something with
the settings here, but I took a look at the models and its working.
regards,
Alfonso
