undo redo
slefebvre1
undo redo
Hi Everybody,
Has someone already met problems with the fonctionality "undo-redo" in creo2 which doesn't work ?
Thanks four your tips..
regards,
Stéphane
I don't think every action can be undone, but I'm not sure what things can't.
Also, I believe that activating the window resets the undo list.. Once you activate the window, undo and redo will not work.  There are other actions that do the same, but I don't recall what.
LinkedIn
Robinske
(To:slefebvre1)
We had issues with undo/redo greyed out but this was due to Pro/Program items in the start parts (see CS153272 in tech support)
Description
  • Undo and Redo functions are grayed out using a start part/assembly
  • New created part/assembly model have undo/redo disabled and grayed out
Applies To
  • Pro/ENGINEER and Creo Elements/Pro Wildfire to Wildfire 5.0
  • Creo Parametric Creo 1.0 to Creo 3.0
Cause
  • Model contains a Program
  • Template used to build parts and assemblies contains a Program
Resolution
  • Reported to R&D as SPR 2204100
  • Works to product specification for Pro/ENGINEER, Creo Elements/Pro and Creo Parametric
  • Remove Program in the Template. Demo
  • For existing parts and assemblies, user has to remove Program manually
