zip gaps
sneg3691
zip gaps
We updated to W/F 4.0 from 3.0.
Can any of you folks that are experienced with repairing imported geometry
explain to me how to go about zipping gaps within W/F 4.0. In W/F 3, it was
under the geometry tab. Under 4.0 it appears to be under import data doctor,
but I see no zip gap functionality there. it got to be somewhere.
Thanks.
Best regards
Kelly Gensley
Genz Design & Machine L.L.C
Box 232
Victor, Iowa 52347
Hi Kelly, just follow the steps below.
Enter in Import Data Doctor by the following steps:
Select the imported feature and do Edit Definition.
Geometry -> Import Data Doctor or button
Find the gaps:
Access the repair mode
Start the search tool
Change the “Look for” option to look for Gaps.
Enter an appropriate value for the gaps to search for.
Find them and add them to selected items box and close the search toolbox.
Add them to the wireframe and repair the model .
Patrick
There is a "Getting started with Import DataDoctor" PDF tutorial incl.
models in Pro/ENGINEER Help Center that comes with your install.
Just click Tutorials under Quick Links and you will find it.
Bjarne
Gensley Kelly <->
15-07-2010 19:18
Please respond to
Gensley Kelly <->
To
cc
Subject
[proecad] - zip gaps
geometry explain to me how to go about zipping gaps within W/F 4.0. In
W/F 3, it was under the geometry tab. Under 4.0 it appears to be under
import data doctor, but I see no zip gap functionality there? it got to be
somewhere?
Thanks?
Best regards
Kelly Gensley
Box 232
Victor, Iowa 52347
