Tried to start Creo this morning which failed. I have had this before and used manual activation, but when I try this today I get a 404 error (address is https://www.ptc.com/appserver/securePeModeling/peManualLic.jsp?lang=en&u=Niall etc)
How can I start Creo?
Yep, any Updates ??
Same Problem: Would be great to have a solution quick. Need to do some work urgent! 🙂
Good day all -
We are continuing to work the issue and I will supply updates as I have them.
Sorry for the delay and I appreciate the patience.
Best,
Toby
Good day,
Looks like this is fixed.
Please let me know if any issues remain.
Best,
Toby
Toby,
I can certainly get back onto the manual activation server. Thank you:)
However it is still not license checking automatically, is this still an issue? Or is there a further step I need to take?
Regards
Niall
Hi Toby,
I just tried: I'm back in and everything seems to be going OK, Thanks a lot!!
Fred
since yesterday 11 April 2018 the problem "Creo elements will not start two to connection error and manual activation fails"
How can the activation problem be resolved?
The most appropriate thing would be to call PTC Tech support. The community can't do much other than give advice.
Good day all,
I will provide updates here
Re: I get no license from ptc server and can't start ptc creo elements - is the ptc server down??
I will lock this discussion to stop duplicate conversations.
Best,
Toby
Sorry guys, this morning I've try to connect but have the same issue as last year, Is the server down again or it's just me?
Got the same problem since a few hours!
Hope it get fixed real quick, because i have a important project running. And just 2 weeks remaining for my degree dissertation in university.
Any tricks to start working again?
In the past, Toby has helped Creo Elements Direct users with a PTC license server issue.
See this discussion https://community.ptc.com/t5/Additional-Creo-Questions/I-get-no-license-from-ptc-server-and-can-t-start-ptc-creo/m-p/163816
Seems like a problem on the PTC side has occured again.
Thank you for bringing this to our attention. I sent this thread to internal Creo teams for review.
Still not working for me . . . has been at least a week or more that an Activation Key pop-up has been happening. free Elements user
Is there a forecast when a fix will be in place ?
Not working now either
HI, I just started having this problem starting Friday 5/21/2021. Same exact issue. Is there a solution for this?
Thanks.
