ProUITree widget
vinaym
ProUITree widget
Hi all,
Has anyone used ProUITree widget available with Wildfire 3.0?
I am trying to create a Tree structure as shown below.
|-Vertices
| |-Vertex1
| |-Vertex2
|-Edges
| |-Edge1
| |-Edge2
|-Faces
|-Face1
|-Face2
I am able to add Vertices as the Tree Node with following code.
MyDialogName is the name of the dialog
ModelTree is the Tree widget added to the dialog in .res file.
// Following line returns PRO_TK_NO_ERROR
status = ProUITreeNodeAdd("MyDialogName","ModelTree","Vertices",
L"Vertices",NULL,PRO_UI_TREE);
// Following line returns PRO_TK_GENERAL_ERROR
status = ProUITreeNodeAdd("MyDialogName","ModelTree","Vertex1",
L"Vertex1",NULL,PRO_UI_TREE);
status = ProUITreeNodeAdd("MyDialogName","ModelTree","Faces",
L"Faces",NULL,PRO_UI_TREE);
But any further node addition to the tree results in PRO_TK_GENERAL_ERROR.
This is how my dialog looks like with the above code.
Vinay
0 REPLIES 0
