no spring force?
hubenduben
1-Newbie
no spring force?
hi
i have a really simple problem but i dont get it to work.
i have two moving parts. i created a spring between them (2 points). the spring is displayed and the display is bevahing like a spring.
i created a meassure res force and clicked the spring.
the meassure sais "not calculated"
i know i do wrong something really stupid. forgot something or whatelse. but...
this is really simple but i dont know why i cant meassure the spring force?
thanks in advance
Make sure that the analysis that you make was dynamic type. Is needed for calculate forces
4 REPLIES 4
Welcome to the community huben duben.
Do you have a prt file you could share? Or a screenshot? It might help members understand exactly what you're after.
-Dan
thanks for reply
i cant share the real model.
i created a really simple model to look for the problem. in this simple model i added just a bar with a pin joint and a servo. i created a spring between ground and a point on the bar.
i created a meassure for the spring force. (res force)
i run the simulation. the bar is rotating, as expected. the meassure for the force sais "not calculated" > why?
(will attach screenshots later)
regards
huben
i was sitting in front of the forrest and not able to see the trees..
thanks!
