AndrewK
Community Manager
August 7, 2023
Inserting Code Samples in Community Posts
  • August 7, 2023
  • 0 replies
  • 5678 views
If you need to share code in a community post, you can use the "Code" option in the three dots menu.
A new window for you to insert your code pops up, with a code preview at the bottom.
There is syntax highlighting available for a variety of languages.
Apache
Bash
C
C#
CSS
Diff
HTML
HTTP
INI
Java
JavaScript
JSON
Makefile
Markdown
Nginx
NQE
Objective-C
Perl
PowerShell
PHP
Python
Ruby
SQL
Swift
VBScript
XHTML
XML
YARA
