thread hole size
ssa
Newbie
Newbie
thread hole size
can anyone tell me where i can find info on this thread hole size as in pic. what is ... H clear
Re: thread hole size
What program is this from?
proE probably wildfire 2, i thinks it's use old convention.
This question is in the wrong forum. This forum is for Creo elements/direct not proe or wildfire.
it doesn't matter what version is being use, the definition is the same what ever program you use it . the definition doesn't change even if you were to use AutoCad , solidworks ...
It does make a difference when it comes to formating, and error messages.
For example. This is how the formatting is defined in Creo elmenets/Direct.
"Dimension/Specific/Thread/Format" :M
"Dimension/Specific/Thread/FormatStyle/Format" "<thread-profile><nominal-diameter> x <pitch> X <length>"
"Dimension/Specific/Thread/LabelLeftHand" "Left-handed"
"Dimension/Specific/Thread/LabelRightHand" "Right-handed"
"Dimension/Specific/Thread/Postfix" ""
