hi,
i have a problem with Creo View; sometimes whern opening an assembly trough Windchill the loading bar get stuck at 99% (more or less) and it never grows.
Our version is old but it never shows before
Creo View 3.1
Windchill 10.2
Creo View 3.1 is not supported anymore - ideally you shall upgrade to latest version (of both Windchill & Creo View too). This is most likely the issue browser restrictions or missing content.
You can capture logs to investigate in more detail Article - CS62972 - Capturing Creo View and Creo Illustrate debug trace logs for troubleshooting
Hi @cspinelli,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
