I am using Creo Schematics Release 7.0 and Datecode7.0.0.0
Application scenario: In the process of drawing the schematic diagram, it is found that there is no required Cable in the existing Cable library. At this time, the maintainer of the Cable library needs to create the required Cable and update the template file. Draw the schematic diagram above; in this case, the schematic diagram that has been drawn before will be wasted and can only be redrawn;
Requirement: Because the Cable library needs to be managed in a unified manner, it is necessary for the management personnel of the Cable library to import the newly added Cable library file into the computer of the schematic drawing personnel to use it directly, instead of reinstalling it in a new one. Draw on the basis of the template file;
Translated by Andra Chirila using Google Translate on February 10, 2023
应用场景:在绘制原理图过程中,发现现有的Cable库中没有需要的Cable,此时需要Cable库的维护人员创建了需要的Cable后,将模板文件更新后,制图人员在最新的模板基础上绘制原理图;这样的话,之前已经绘制出的原理图就白费了,只能重新绘制;
需求:因为Cable库需要统一管理,所以需要Cable库的管理人员能够像管理Connector库那样,将新增的Cable库文件导入到原理图绘制人员的电脑上能直接使用,而不是要重新在新的模板文件基础上制图;
Title translated by Andra Chirila using Google Translate on February 10, 2023
Cable库
