I am using Creo Schematics Release N/A and DatecodeN/A
When I create a new project it asks me to use
template design “C:\Program Files (x86)\PTC\Creo
3.0\M010\Schematics\creoschematics\demodb.rsd”, if I don’t select this then I
don’t see any components in “Catalog Explorer”, Is there a way to manually set
the path to symbol library??
There was a similar question before - "Help with Creo Schematic": https://community.ptc.com/t5/3D-Part-Assembly-Design/Help-with-Creo-Schematic/td-p/188715
