Hello Community,
If I open an assembly from Windchill in Creo View and add annotations and/or save annotation sets to the assembly:
Will the engineer see these annotations/sets in his Creo Parametric when he continues to work on the assembly?
Regards
David
The pipeline of data transfer and authoring information flows from Creo Parametric into Windchill Publisher to Creo View...and information authored in Creo View gets pushed back into Windchill...but nothing authored in Creo View can be seen in Creo Parametric. (There has been some companies that have set up configurations to select objects in Creo View and then open the corresponding structure in Creo Parametric.)
Thanks for clarifying!
