Creo Illustrate 3.0 Installation Error
jheld
I am encountering an error when trying to install Creo Illustrate 3.0. Please see attached screenshot for the error window. I have also attached the error log. Please reply with questions or possible solutions.
5 REPLIES 5
MartinHanak
(To:jheld)
Q1:
Did you unzip downloaded zip file -AND- then run setup.vbs ?
Q2:
Did you launch installation as Administrator ?
MH
Martin Hanák
Yes, I have unzipped and then run the setup.
Some programs I can right click on and run as administrator. I do not see that option for this one.
Thank you for your help.
JH
MartinHanak
(To:jheld)
I think you can open Command Prompt window as Administrator and run setup command from this window.
MH
Martin Hanák
VladimirN
(To:jheld)
Can you attach this log file "pvinst_illustrate.log" to the message? Also you can open a new "Case" for PTC's technical support about this issue here: https://support.ptc.com/appserver/cs/case/case_logger.jsp
I'm having the same error with my installation. I was wondering if there is a solution or case about this?
Kind regards
