We’re aware that the eSupport site is currently down, preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
Can anyone suggest the best way to edit an animation I have created?
I have had to removed some now unwanted parts that I had animated (i.e. bolts with an unscrewing effect) but I now need to edit the duration of that section as the animation looks like its doing nothing for this duration? Can I just cut out a section of the track length or the top level Animation track and if so, how??
Thanks for any help,
Brian
The easiest way is to select all the tracks after the gap and drag them back to remove the gap.
It may be easier to select these tracks using the tree:
Hope this helps.
Hi Adrian,
Many thanks! Makes good sense.
Thanks for the help...Again!
Brian
