Creo Schematics 7.0 - PDF export issue compare to CS 3.0
Ramesh_Mani
7-Bedrock
There is an issue we are facing during PDF export from CS 7.0 compared to previous version CS 3.0 (used before CS 7.0) as mentioned below.
  1. The exported PDF from CS 7.0 (15MB) file size is 3 to 5 times larger than CS 3.0 (3MB). We just wonder why this drastic file size difference from older to newer versions. Sometime, it is taking more than 5 minutes to create the PDF file on CS 7.0.
  2. The exported PDF from CS 7.0 and open in Adobe Illustrator for edit text properties is automatically changing the TEXT format into DARFT format. Please refer attachment for more details.
Hi Ramesh_Mani
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
I think the attachment gives more details, here are some additional details.
We used to color the circuit/wire name based on the functionality in Adobe Illustrator (AI). For formatting in Adobe Illustrator (AI), we use the PDF file exported from the RSD file saved from Creo Schematics. We do not face any issues in the older version of Creo Schematics (CS 3.0). After we deployed CS 7.0, the exported PDF file is selectable as a "TEXT (single word)" in PDF format. When we import into Adobe Illustrator (AI), the "TEXT (single word)" becomes "STROKE (single letter)" format.
Creo Schematics version we use: CS 7.0 F000
Adobe Illustrator version we use: Ai 28.4.1
