Creo View Publishing HPGL but one sheet scale is off
avillanueva
Odd problem but here you go. I have an assembly drawing. We publish using default HPGL/2 format. Everything in Creo View 9.1 looks fine except 1 sheet seems to have drawing extents that are off. In Creo Parametric 9 its fine. All other sheets are fine, D Size and when you view or Print to PDF, sheet 2 appears scaled down and not maximized to the paper size. Very odd.
When I've seen this in the past, its been due to a piece of geometry or sketched entity outside the field of the drawing border except we cannot find anything. Any other reason for this behavior? The drawing bounded boxes also appear inside the field of the drawing too.
Sheet 1 above normal. Sheet 2 below not normal
I have config.pro option add_clip_command_iw_hpgl YES to prevent publishing outside the format:
https://www.ptc.com/en/support/article/CS151405
