Hi All
is there a setting in CreoView to make the Section 3D Dragger to be in the Viewing Screen.
Currently when in section and you select the section plane to move the section the dragger is in the middle of the model. in our case the model is 85m long x 20m high makes it very hard when trying to section at component level.
would be good to have the dragger to behave the same as the Component Transform dragger see attached files
We are using CreoView 8.0
many thanks
David
Hi David:
This is product limitation with Creo View. I would recommend to create a Product Idea, so other customers can response to same.
For few other issues related to dragger there already exists an Idea https://community.ptc.com/t5/Addtl-Creo-Ideas-Creo-View/Drag-Section-Plane-with-Mouse-amp-Keyboard-in-Creo-View/idi-p/470176 that may help.
