Customising Callouts in Creo Illustrate (2.0 M020)
TheodorusBoudew
6-Contributor
I want to create a callout in Creo Illustrate that shows the Description of the object as the text in the callout.
I can see the description property in the pvs file in Creo Illustrate but I cannot get it to populate the callout.
I have added the following snippet to the CalloutTemplates.xml file :
<annotation id="ship-description" hasLeaders="true">
<name locid="DEFItemNumber-SHIP"/>
<description locid="DEFItemNumberDescription"/>
<tooltip locid="DEFItemNumberTooltip"/>
<thumbnail url="ship_note.png"/>
<leaders>
<line-style weight="1pt" color="#000000" halo="false" dashes="Solid" start="none" end="none"/>
</leaders>
<label canEdit="true">
<text font="Arial" size="10pt" color="#000000">
<useproperty category="PVS File Properties" name="Description"/>
</text>
<shape type="rectangle"/>
</label>
</annotation>
Did I reference the property value correctly.
I have another (Creo Parametric based) example that has description in the category PROE Parameters and that one works fine.
I also looked at the Creo Illustrate help. But cannot find any reference to customising callouts or any limitations.
Any help or advise is much appreciated.
Theo
6 REPLIES 6
Hi Theodorus,
The latest Creo Illustrate install guide (https://www.ptc.com/view?im_dbkey=148898) has two new appendices on customizing annotation styles by editing the callout templates XML file.
Unfortunately, the <useproperty> examples on pp. 91-92 only cover category="PROE Parameters" and category="System".
It *should* work for category="PVS File Properties" as well...but I'll have to look into this.
Meanwhile, you might try substituting category="PROPERTIES" (all caps) for category="PVS File Properties" and see if that works (This is just a hunch.)
Mark
Theo
Congratulations. You've found a little bug
I just tried this myself, and found it will *not* work for PVS File Properties.
It *will* work for other property groups e.g. PROE Parameters, WindchillEPM, WindchillPart etc.
The bug is basically in handling "PVS File Properties", which is a 'magic' attribute group. It is so magic that it doesn't actually have a name - the group category title is, in fact, "" (empty string) and the callout template code is not dealing with this correctly.
Can you submit an SPR please?
thanks
-steve
Thanks Steve,
I will log a case with Tech Support and ask them to raise an SPR.
In the mean. I am trying to show something during a demo. I have proe dataset that I can use to show an example but the data is not that relevant to the customer.
Is there a way to show the Item Tag in the call out (as created in the items list).
The call out template has an example for item number and quantity :
<useproperty category="System" name="pvITM"/> x<useproperty category="System" name="pvQTY"/>
It uses the category System. What other properties are part of the category 'system'. I have tried pvItemTag and various variations of that but that doesn't seem to work.
An other options could be component name.
Any ideas ?
Theo
Hi Theo
you can currently use pvITM, pvQTY
Support for pvTAG has been added to x24 (Creo Illustrate 3.0)
tag =<useproperty category="System" name="pvTAG"/>
-steve
Hi Steve, One more question about callouts, hope you can help. I want to combine multiple property values on the callout as seen below:
<annotation id="ship-partnumber" hasLeaders="true">
<name>Part Number</name>
<description>Part Number</description>
<leaders>
</leaders>
<text font="Arial" size="8pt" color="#000000">
Item <useproperty category="System" name="pvITM"/> - <useproperty category="WindchillPart" name="part_number"/>
<useproperty category="WindchillPart" name="part_name"/>
</text>
</label>
</annotation>
I want a 'new line' between the part number and the part number so it creates a callout with 2 lines in it.
Is this possible and what character string should I use for a new line.
Thanks again,
Theo
yes, just insert a <br/> tag in the text e.g.
Item <useproperty category="System" name="pvITM"/> <br/> <useproperty category="WindchillPart" name="part_number"/>
