I would like to do two things with Java API.1.Can I automatically assign color to the wire (Fiber) using the property color?2. For unconnected pins, the Connection point is set to 0, but the term name is the part name that we have assigned in the CSV files. Can You say with Java API when connection point is set to 0 that it takes term name Empty?
Hi nclaerhout
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
