We are working from a Parts List in Windchill, which creates a c3di file. When we Update Illustration and open the c3di file in Illustrate, every part that has an Item Number will have an annotation applied to it. So if I have 50 parts in the model, all of the parts will have an annotation when it is first opened. Also, when I make a new Figure, it does the same thing. It does this every time you open the c3di file whether it was saved like that or not.
Is there a command that tells Illustrate to automatically populate every Item Number by default in some config file somewhere? I tried looking but I couldn't find anything.
Windchill 11.1
Illustrate 6.0
Mike
The callouts are generated automatically for new and updated figures, there is currently no way to control whether the callouts are created for all itemised parts.
I would suggest submitting an idea to the Creo Ideas site if there is an enhancement to this behaviour you would like to see:
https://community.ptc.com/t5/Addtl-Creo-Ideas-Creo-View/idb-p/creogeneralideas
We monitor the site for ideas related to Creo Illustrate.
