I am trying to fix the issue of drawings printing black from Creo viewer. I am looking at Document CS94057 and under the workarounds section, it says
Where can I find the System Environment Variable in the Creo View runtime environment?
Alyssa
Jason,
This isn't a Creo View environment variable, but a computer variable. You will need to access your system's properties and set it there.
