Hallo,
I work with Pvz files in Creo Illustrate 9.0.
The concerned parts that do show in Creo Illustrate are the "Model Construction Geometry Surfaces".
The Pvz file does contain them and is not the problem.
These parts do not however show in the Svg export.
These "Model Construction Geometry Surfaces" concern parts we buy, for example a gearbox or an air filter.
These parts are used in our Cad models, next to the parts we model ourselves.
I am working on a parts catalogue and I need all parts to show in the Svg (an exploded view).
how can I make that happen?
thank you in advance
Unfortunately, there is no way to 'force' construction geometry to be included HLR exports (svg, cgm etc ...).
Only 'real' geometry is included when generating the HLR, so to include these construction parts you would need to get the source file updated to make them real geometry.
Sorry i can't be more helpful.
