Create > Scale > Edit > Use >>> your Sketch - quickly and easy with Creo Parametric
Thanks Vladimir. I like these simple kind of tips because I usually learn a short-cut that I was not using. I use the same technique to scale my sketches, but I did think of using the "Modify" option found in the short-cut menu.
Nice beat in your video, too.
Hello Kevin
You are welcome, if you want listen all songs click here ![]()
Vladimir
I too enjoy these brief video tips that help speed up my "design" day! Thanks Vladimir!
Best regards,
Bob Barker
