Transform Dragger...
bwhelan
A very quick question: How can you move the Transform Dragger so that it appears in a zoomed view of a large assembly? Quite often, I need to transform the location of a large object, but need to look at a detailed zoomed view while moving the object, but the Dragger could be located at some distance from the required view. I know I have seen the answer to this before but can't find it!
Thanks in anticipation,
Brian
2 REPLIES 2
You can change the transform dragger location using the RMB option 'Location' and then 'Select csys' but this does change the coordinate system to the selected part.
I think what you are asking for is that the transform dragger stays 'in view' when zoomed in on a large assembly.
This is an enhancement that will be available in the next release of Creo Illustrate (4.0) which is due out later this year.
bwhelan
(To:bwhelan)
Thanks Adrian. Much appreciated. Roll on Creo Illustrate 4.0!!
Brian
