Use the environment variable "HOME" to costumize the User Interface
SebastianDrees
In the old ProE environment it was possible to use the variable "HOME" to set the the path for the login-ID. In this way ist was possible to make a configuration for the users in this folder. With the start of ProE were this configuration used to create the interface. For the new UI-File this configuration is not possible.
3 REPLIES 3
You may want to vote on your own idea.
And on this one:
http://communities.ptc.com/ideas/2713
Thanks, Dale
Hello Dale,
what is this link. I cann't open it.
regards Sebastian
Should be fixed now.
There's another idea that was added so links would be posted correctly, but I don't remember which one that was.
