Using "Link" option
VladimirN
Using "Link" option
Hello!
I think that it need to be added into Creo Illustrate the ability to import CAD models using a relative path to locate the source CAD file. That is, need to create a check box that allows the user to use or not a relative path for the inserted/imported 3D CAD model. I hope this feature will be implemented in the next version of Creo Illustrate. So what do you think?
"Link" option in Creo Illustrate 1.0 M030 ("File" -> "Import" -> "Link"):
Need to added check-box option "Use relative file path":
0 REPLIES 0
