According to PTCs document comparing the different versions of Creo View, in Creo View Express you should be able to "Display Combination or View States from Creo Parametric" but I cannot figure out how to view them once in Creo View. Any suggestions on how you would do this would be appreciated.
Go to:
"your drive":\PTC\Creo 2.0\Common Files\M120\text\prodview
Open export_pvs.rcp with notepad and change adapter/outputAuthorState=1.
Save your file as .pvz and open it in Creo View.
Go to:
