WARNING - cannot place cross sheet graphics if the DEF_SHEET_FORMAT layer is protected.
BillF
Does not matter if the graphic has anything to do with the layer.  May be a problem with other layers being protected.
You can extend fibers across sheets, just not with a graphic.
The error that is given is the generic ">>>> error <<<< Internal Error (001) occurred..."
0 REPLIES 0
