Is it possible in Simulate investigate the behaviour of body fixed on slide carriage with acceleration force?
Thank you
When use "Gravity Force", it is necessary that the WCS is in centroid G of the mass;
if not, I need to create a new coordinate system with X = Xg, Y = Yg, Z = Zg, correct?
yes
If I would like to consider the own weight (z = - 9.806 [m/s2]) of the 3D body that is in Simulate, I need add a Ideal mass in the Centroid G?
gravitation works on all bodies
what is the purpose of these?
Thank you
What does it mean this?
Warning: Resultant measure Forza_10
may not be evaluated correctly because there are
multi-point constraints (MPCs) near the resultant measure.
MPCs may occur in models with mixed or
incompatible meshes, links, fasteners, or
user coordinate system (UCS) constraints.
I found this topic
https://www.ptc.com/en/support/article?n=CS95825&source=snippet
So, also in your example the surfaces of measure and of the rigid link are the same...
my weightet link is correct:
