Angle between shell normal and solid normal must be greater than 45 degrees
gpommeranz
I get this warning message any time I'm working with weldments larger than 2 parts: "the angle between the normal to the shell and the normal to the solid face at a shell-solid link must be greater than 45 degrees.  The link(s) will be ignored".  Can anyone tell me what Simulate is doing?  The diagnostic tool highlights elements around these connections but as far as I can tell connectivity is maintained.
Garry, I know this is WAY late, but the only thought I have is that it could be due to the same reason of the May 15 comment here: Re: How to fix degenerate boundary faces in Simulate, where Creo just doesn't like shallow angles.
I have had this before where standard shells and shell idealizations intersect solid parts, but not with weldmelts.
