Boring through holes
Not applicable
<p>I am a newbie at CAD and CoCreate. However, in the first hour or so I was able to create 2D of a design I'm working on and extrude it (I think). However, when I try to use the Bore tool under extrude to bore countersunk holes, I'm not able to figure out how to do this. I keep getting warning messages that the direction of rotation is not in the plane. I've snapped a screen shot below to show you my scenario. Any hints/directions much appreciated!</p><p></p><p><img border=""0"" src=""file:///C:/DOCUME%7E1/JEFF%7E1.PC1/LOCALS%7E1/Temp/moz-screenshot-2.png"" /><img border=""0"" src=""file:///C:/DOCUME%7E1/JEFF%7E1.PC1/LOCALS%7E1/Temp/moz-screenshot-3.png"" /><br /><img border=""0"" src=""file:///C:/DOCUME%7E1/JEFF%7E1.PC1/LOCALS%7E1/Temp/moz-screenshot.png"" /><img border=""0"" src=""file:///C:/DOCUME%7E1/JEFF%7E1.PC1/LOCALS%7E1/Temp/moz-screenshot-1.png"" /></p>
ptc-1796973
(To:)
Your terminoligy is getting you. First, example is if you want to put a hole through a part, you'll have a circle on a workplane and you will use the ""punch"" command and it will put the hole all the way through a part or list of selected parts (see below) Next, if you want to put a counter bore on an existing hole, you would have a circle on the workplane as shown below and then use the ""Mill"" command and give it a depth. Finally, if you want to do both at the same time, your workplane would need to be 90 degrees to the face that the hole and counterbore are in and then you'd create the outline (1/2 of the hole and the counterbore as shown), and the ""Bore"" it around the long axis. You can't really tell it, but that workplane and outline is in the middle of that part.
